Date/Time: Sun, 19 May 2024 13:52:30 +0000
Number bars as in the picture
View Count: 668
[2016-11-21 18:55:32] |
User252419 - Posts: 235 |
Hello, I've tried all the Background Coloring Method configurations but I can't have the same configuration as in the picture. What should I do to have exactly the same Number bars ? Thank you, |
[2016-11-21 19:25:19] |
We do not understand specifically what the question is. You need to be very very specific about what you require and just ask us about one particular item at a time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
