Date/Time: Tue, 28 May 2024 17:13:45 +0000
Crossover
View Count: 1077
[2016-11-21 17:24:04] |
User814739 - Posts: 1 |
I am an Apple Macintosh user and want to use Green Charts. One option for running Windows-based software (such as the charts) is to use the Mac app called "Crossover." As I understand, Crossover creates a box in the Mac screen, within which Windows runs. If Green Charts will run using Crossover, I could see the charts in the Crossover box, while using the broker's website on my Mac and making trades. This sounds good, but I don't know for certain that Green Charts will run in Crossover. Do you? thx, Dan Carpenter |
[2016-11-21 17:59:28] |
We have heard that this works, but if there any technical problems we cannot help with those. We do not think this is a good technical solution. It inherently is going to have reliability problems. You instead need to use a solution where you can install Windows on your Mac and run Sierra Chart directly on Windows. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-21 17:59:48
[2016-11-22 16:02:38] |
ganz - Posts: 1048 |
User814739 Crossover creates a box in the Mac screen, within which Windows runs.
No. It uses WINE https://www.winehq.org/Don't waste the time with it. |
