Date/Time: Sun, 19 May 2024 16:56:20 +0000
Tile and Spreadsheets from other Chartbooks
View Count: 622
[2016-11-21 15:47:42] |
GC15 - Posts: 7 |
When I try to tile or cascade the windows in a chartbook it does so as though spreadsheets from other chartbooks are included in the current chartbook. It's most noticeable when trying to tile because if I only have four chartwindows in the current chartbook, but five spreadsheets open in other chartbooks, they will end up in a 3x3 grid instead of a 2x2 grid. When the tiling actually occurs (or cascading) the spreadsheets will become momentarily visible in the current chartbook then disappear just after arranged and I'll be left with a 3x3 layout with five windows missing (see attached). I'm currently using version 1488 and have noticed this for the past few versions.
Private File |
[2016-11-21 18:31:45] |
This will be resolved in the next release.
[2016-11-21 19:37:58] |
GC15 - Posts: 7 |
Thank you!
