Date/Time: Sun, 19 May 2024 18:16:40 +0000
Making my own custom studies
View Count: 764
[2016-11-21 13:36:58] |
User514837 - Posts: 47 |
Hello, when you create and build your own custom studies, do these get uploaded to a server? If yes, is it also that anyone can access it unless you create a list of authorized users?
[2016-11-21 15:30:14] |
Sierra Chart - Max - Posts: 5618 |
You have the option to do this. Refer to the documentation here: Advanced Custom Study Interface and Language (ACSIL): Redistributing and Allowing Use Only by a Defined List of Users To restrict access to a list of authorized users you will have to add the specified code to your studies, as is documented in the provided link above. Sierra Chart Support |
[2016-11-21 17:45:41] |
No. They do not get uploaded to a server. There is the capability to do a Remote Build, but there are no files saved on the server when that is used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-22 19:05:18] |
marcovth - Posts: 61 |
Is there a command line that I can use inside Notepad++ to Remote Build?
[2016-11-22 19:08:52] |
No. Not at all.
