Date/Time: Sun, 19 May 2024 17:52:13 +0000
Volume Profile: Questions on Extend Value Area & Peaks & Valleys
View Count: 1078
[2016-11-21 05:10:27] |
vrunrun - Posts: 53 |
Hi SC, Is is possible to overlay the "Extend Value Area" and also "Peaks & Valleys lines" in volume profile to other charts? I've set them to "Until Further Intersection". I've checked to display both name labels and values in Subgraphs Settings but only the values are displayed in volume profile chart. Pls check. Thks. |
[2016-11-21 05:50:05] |
This is definitely not supported.
