Date/Time: Sun, 19 May 2024 15:52:10 +0000
Vertical Time Line
View Count: 1086
[2016-11-21 01:30:13] |
Rino - Posts: 124 |
Hi, I can not get the vertical time line to show. Do you see anything wrong with my settings? Thank you, |
[2016-11-21 02:41:33] |
From our perspective this is hard to say. But try increasing the Allowed Range for Match in Minutes Input.
[2016-11-22 15:22:24] |
Rino - Posts: 124 |
I simply want to have a Vetical line as shown in the screenshot. A Vertical line is not a choice? Thanks as always |
[2016-11-22 18:48:59] |
Using the same settings you have showed, we see the Time Line displayed on a chart for the same symbol and same bar period: http://www.sierrachart.com/image.php?Image=1479840502513.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-22 18:49:44
[2016-11-23 01:55:55] |
Rino - Posts: 124 |
Once again thanks. Especially for taking the time to duplicate my setting to show me it works. Now you may be mad when I tell you what I did. The main reason I am telling you is so if it happens to someone else, you know what they probably did. Lol I changed it to line. As long as you leave the default settings it works. Truth be told. I changed it because I would not think I should leave it as "Right Offset Box Bottom" I was changing that to line. (Because I wanted a line. Lol) |
[2016-11-23 05:04:08] |
You are running a version where the Subgraph Draw Style list box is not displaying the correct text in some cases. Update Sierra Chart to the latest version. Select Help >> Download Current Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
