Date/Time: Sun, 19 May 2024 17:52:05 +0000
accessing TWS from another computer
View Count: 1016
[2016-11-20 19:14:51] |
Litz - Posts: 131 |
I am running a second copy of SC on another computer and wish to access the IB data feed on this computer. The IP config address is assigned an internal IP address 192.168.------ by the router, while the external address is a different address. Question is how to configure the Data/Trade Service Settings to access the TWS on this computer. Do I change the server address and port to the internal or external address? ie: 192.168 .n.n:7496? |
[2016-11-20 20:57:15] |
Litz - Posts: 131 |
Figured it out. Used the internal IP and had to assign a new Instance Client ID.
[2016-11-20 20:59:46] |
The Server Address needs to be the internal IP address if both of those computers are on the same internal network.
