Date/Time: Mon, 13 May 2024 09:44:56 +0000
Market Depth Hist. Gragh Shading
View Count: 1279
[2016-11-18 16:06:57] |
conr - Posts: 204 |
Is there any way you can add more settings so as to get better level contrasts. As you can see in the first image you can barely make out the depth differences. The second image shows greater contrast if I move the bars way to the left. http://www.sierrachart.com/image.php?Image=1479484864931.png http://www.sierrachart.com/image.php?Image=1479484993673.png |
[2016-11-18 17:36:39] |
Refer to the Input descriptions here: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs Change the Colors to white. This will give a greater range of color display. Also try experimenting with changing Minimum Volume Intensity Percent setting. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-19 16:26:23] |
conr - Posts: 204 |
Thanks, it seems to help a bit. Question regarding an additional feature. Are you able to add volume dots(filtered by min. volume) directly on the chart? The dots' size and color would depend on the bid/ask volume. Keep in mind, this would not be market depth but actual volume transactions at each price level. |
[2016-11-20 01:05:13] |
We expect to get to this in the first quarter next year.
[2016-11-20 17:37:06] |
conr - Posts: 204 |
That is great news.
[2016-11-22 14:50:04] |
conr - Posts: 204 |
Been trying to adjust and no improvement. Only when I move left. http://www.sierrachart.com/image.php?Image=1479826158808.png http://www.sierrachart.com/image.php?Image=147982604414.png |
[2016-11-24 21:05:53] |
Neo - Posts: 198 |
conr Question regarding an additional feature. Are you able to add volume dots(filtered by min. volume) directly on the chart? The dots' size and color would depend on the bid/ask volume. Keep in mind, this would not be market depth but actual volume transactions at each pric
Sierra Chart Engineering We expect to get to this in the first quarter next year.
Can I propose a method for calculating the "volume dots/ bid/ask volume"? Or have you already decided how you will implement this. |
[2016-11-24 22:08:12] |
No not now. We have to implement it appropriately and then we will look at feedback later.
[2017-01-07 20:47:11] |
conr - Posts: 204 |
Now that we are into January do you have a better timeframe |
[2017-01-07 22:30:36] |
Question regarding an additional feature. Are you able to add volume dots(filtered by min. volume) directly on the chart? The dots' size and color would depend on the bid/ask volume. Keep in mind, this would not be market depth but actual volume transactions at each price level. Videos | Post: 106198 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-18 15:09:01] |
conr - Posts: 204 |
http://www.sierrachart.com/image.php?Image=1479826158808.png http://www.sierrachart.com/image.php?Image=147982604414.png Been playing around with this and no improvement. Hope you can work on. Thanks. |
[2017-01-18 17:49:57] |
What is the question?
[2017-01-18 19:16:48] |
conr - Posts: 204 |
[2017-01-19 02:32:31] |
The 3 settings which will help with this are: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_BidColor https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_AskColor https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_MinumumVolumeIntensityPercent Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-26 13:45:04] |
conr - Posts: 204 |
Been playing around with the shading/contrast for a while now and there just isn't enough contrast. Any chance you may be working on improving? Thanks. |
[2017-04-26 17:43:47] |
We do not see what further improvement can be made. Every possible Input to give you the capability that you need, now currently exists. This is the newest input added in the latest release: http://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_MaximumQuantityForColoring Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-04-27 01:58:47] |
User19165 - Posts: 346 |
Hi conr, Something that has helped my charts with this is to set the "graph only quantities greater or equal to" to something. This cleans the chart up from a lot of noise and lets the indicator apply more meaningful contrasts, I feel. I hope this helps you some. |
[2017-04-27 17:08:49] |
conr - Posts: 204 |
http://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php#StudyInputs_MaximumQuantityForColoring Makes a huge difference. Thank you. |
