Date/Time: Sun, 19 May 2024 22:10:44 +0000
nyse tick
View Count: 591
[2016-11-18 15:06:10] |
User375253 - Posts: 3 |
Can you please help, I would like to add in a seperate pane, nyse tick on my es chart... Thank you. |
[2016-11-18 16:54:01] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php#Overlaying Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-20 02:01:45] |
Ok thank you, but if I'm not trying to overlay from another chart, simply add a new panel with a new study as the tick..
[2016-11-20 02:22:21] |
There needs to be a separate chart open for the NYSE-TICK.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-20 02:22:39
