Date/Time: Tue, 30 Apr 2024 17:51:52 +0000
Customizing Trade Window Buttons
View Count: 2421
[2013-07-31 19:57:49] |
DarthSidious - Posts: 63 |
Can I customize / add 2 buttons in the tradewindow / dom/ chart trading... someplace; so that Buy button will send limit buy at bid + 1 tick Sell button will send limit sell at ask 1 1 tick It will be very helpful - thanks! PS: This is because bid + 1 tick is not always ask and ask - 1 tick is not always bid Date Time Of Last Edit: 2013-07-31 19:58:53
[2013-07-31 20:50:59] |
This already exists through custom Keyboard Shortcuts. Go to Global Settings >> Customize Keyboard Shortcuts >> Commands >> Trading Keyboard Shortcuts.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-31 20:51:21
[2013-07-31 22:35:05] |
There is a predefined command for Buy @ Bid - 1. I need Bid + 1 Also need Sell @ Ask - 1. That isn't there either |
[2013-08-02 19:01:44] |
So, uh, is this a "low priority" or "won't do"?
[2013-08-03 05:18:10] |
Adding these now: Buy Bid + 1 Tick Sell Ask - 1 Tick Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-03 08:54:35] |
These are in the latest revision of 1004.
