Date/Time: Mon, 13 May 2024 16:09:34 +0000
color background based on alert condition
View Count: 934
[2016-11-16 15:02:23] |
User170575 - Posts: 221 |
Good morning, Is there a way to make the entire background change color if a condition is met?? Thx, cj |
[2016-11-16 16:30:50] |
Not of the entire chart. You would need to implement this using ACSIL: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php You will need to use the Background Draw Style for a Subgraph and set all elements of that Subgraph to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-16 16:31:13
[2016-11-16 19:58:50] |
Sawtooth - Posts: 3995 |
This could also be done with the Spreadsheet Study study.
[2016-11-16 20:17:40] |
many thanks---will take a look
