Date/Time: Sat, 11 May 2024 23:24:48 +0000
One watchlist
View Count: 791
[2016-11-16 12:10:03] |
Sporken - Posts: 82 |
Hi, If I add a new stock to a watchlist, it doesn't change the other watchlists for the other charts. I need to manually do it. Is this correct? Is there any way to have a single watchlist for all charts? I can't find a way to get them to automatically read the new symbolfile when it's exported. I can't see a way to get them to share a watchlist with linking either. I looked for an ACSIL watchlist_import method but I can't find one. I see an ACSIL sc.TradeWindowConfigFileName but I cant find an equivalent for the watchlist. I'd like a way to tell the watchlist to import a symbolList file when it changes on disc. I could do this with an ACSIL study. Is there some way I can do this better? I really just want 1 watchlist for everything Thanks again for your help. |
[2016-11-16 16:33:16] |
If I add a new stock to a watchlist, it doesn't change the other watchlists for the other charts. I need to manually do it. Is this correct? The closest to do what you want is to link the Symbol of the charts using Chart Linking: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChartLinking Therefore, when using the Associated Watchlist, on one chart the other charts change to the same symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-16 16:34:13
