Date/Time: Tue, 14 May 2024 19:43:22 +0000
Multiple Drawings
View Count: 611
[2016-11-15 14:29:38] |
User104854 - Posts: 441 |
Hi. I notice that when I have say 2 drawn volume profiles overlapping each other when I click on one it will display 0's around one of them and 1's around the other. Can you please tell me how I go about deleting the one that I want? I can't seem to find it anywhere. Thanks.
[2016-11-15 18:17:49] |
We will verify the documentation explains this clearly, but basically you would just type either a 0 or a 1 in this case, depending upon which drawing you want to delete and press the Enter key.
[2016-11-15 18:31:33] |
Oh I'm sure it does. Just couldn't find it. That's where you come in. Appreciate it.
[2016-11-16 03:50:53] |
This is documented here: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#ErasingDrawnVolumeProfiles Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
