Date/Time: Sun, 12 May 2024 05:24:05 +0000
Can I do a simulation run with Sierra
View Count: 561
[2016-11-15 12:01:08] |
User292365 - Posts: 20 |
Hi. Can I run the sierra chart like a simulator? I would pick a certain date and then the chart will replay and I can adjust the speed at which the candles move. Thanks! |
[2016-11-15 14:06:37] |
wwwingman - Posts: 185 |
http://www.sierrachart.com/index.php?page=doc/ReplayChart.html |
[2016-11-15 16:25:18] |
Yes, Intraday charts can be replayed. Refer to: http://www.sierrachart.com/index.php?page=doc/ReplayChart.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
