Date/Time: Mon, 13 May 2024 03:31:04 +0000
Transparent Background for Bar Numbering Study
View Count: 1169
[2016-11-15 11:01:05] |
User513662 - Posts: 90 |
Hi, I was wondering if there was an option to have the background of the numbers in the bar numbering study transparent. Depending on the scaling of the chart at the time the background of the number overlaps with either the bar to left, right or both. Attached is an example. There may be a workaround or function I have missed but I have not been able to figure it out. Your assistance appreciated. |
SNAG-0045.jpg / V - Attached On 2016-11-15 11:00:13 UTC - Size: 309.34 KB - 263 views |
[2016-11-15 16:37:17] |
We will add an option to use a transparent background for the text of the Bar Numbering study. For now increase the chart bar spacing: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#ChangingBarSpacing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-15 23:17:49] |
Thanks.
