Date/Time: Sat, 18 May 2024 15:41:15 +0000
Remove Sierra Software
View Count: 544
[2016-11-14 19:49:17] |
User416600 - Posts: 5 |
Hi, Can you plese provide instructions for removing Sierra Chart Software from PC? Thanks, RdR |
[2016-11-14 19:55:31] |
This is documented on this page here: https://www.sierrachart.com/index.php?page=doc/download.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
