Date/Time: Sat, 18 May 2024 16:13:57 +0000
Remote Build for Custom Study
View Count: 872
[2016-11-14 19:27:19] |
Marmany - Posts: 303 |
Updated to v1485 and note that in Build Advanced Custom Studies there is the option to "Remote Build". Not able to find reference to this option in the online SC Manual please supply a link source of information on difference between this option and the "Build Custom Studies DLL" option. Many thanks |
[2016-11-14 19:31:05] |
This is not documented yet. The difference is the DLL build is done remotely through our server and has no problems. So if you are running into a problem using the Visual C++ build tools you should use Remote Build. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-14 19:32:16
