Date/Time: Sat, 18 May 2024 14:10:09 +0000
no quotes on spreadsheet
View Count: 701
[2016-11-14 17:56:53] |
taipeicity - Posts: 52 |
I creat a spreadsheet and there are 50 stocks A LOT of symbols have no qquotes, showing all zero, these symbols are INTC, CSCO, MSFT ...... please tell what I did wrong? |
Private File |
[2016-11-14 19:13:22] |
Refer to the Interactive Brokers Stock symbol format here: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Stock You will need to use the symbol format requiring a Primary Exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-14 19:54:56
[2016-11-14 19:14:28] |
The most reliable solution is going to be to activate the US Equities exchange on the Sierra Chart Exchange Data Feed: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-14 19:48:59] |
i have subscribed to IB data feed for nasdaq, nyse .... please look at the image i sent you, the missing quotes INTC, COSO MSFT, DELL .....etc. only spreadsheet, while i have NO PROBLEM LOADING these symbols' charts.... Please, charts are no problem, I have NO quotes on spreadsheet ONLY |
[2016-11-14 19:54:10] |
Our answer remains the same as post #2. Read the response again. We are not going to provide further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
