Date/Time: Sat, 18 May 2024 15:25:07 +0000
obtain older price data - futures
View Count: 614
[2016-11-14 04:08:49] |
Willson - Posts: 176 |
I hvae need for 3rd qtr 2011 ES price data at tick level. I currently use Transact data. How can this price data be obtained? Regards |
[2016-11-14 19:29:09] |
What you need to use is the Sierra Chart Historical Data Service: http://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.php You can then just simply open a chart for ESU11 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
