Date/Time: Sat, 18 May 2024 11:37:09 +0000
Help creating simple indicator
View Count: 1067
[2016-11-14 02:19:01] |
rwilliams1 - Posts: 339 |
Hi, I'm not a programmer in any way, but I'm trying to create a simple triangular oscillator indicator that oscillates around 0 in SC and am not sure where to start. I have the formula (EUR/USD - EUR/GBP * GBP/USD = 0) or (log(EUR/USD) - log(EUR/GBP) - log(GBP/USD) = 0). Either formula will work. But I don't know where to start. Is there an indicator template somewhere that can get me started? Or maybe a way to create the indicator in MS Excel which I'm more familiar with? Also not sure how to reference 3 different instruments in an indicator. Any help is appreciated. |
[2016-11-14 13:35:27] |
Sawtooth - Posts: 4000 |
If you are familiar with Excel, then you should be able to do what you want using the Spreadsheet Study study.
[2016-11-14 17:28:38] |
Here is the documentation for the Spreadsheet Study: http://www.sierrachart.com/index.php?page=doc/SpreadsheetStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
