Date/Time: Sat, 18 May 2024 19:51:11 +0000
Can I use a tick chart on one and a time chart on the other?
View Count: 650
[2016-11-13 17:02:15] |
User292365 - Posts: 20 |
I change the global->data settings to make sure it shows ticks (and I clicked Allow support for sierra chart data feeds since I use a different broker for my data). Then I click: Edit >> Delete All Data And Download Now, if I do this for the AUDUSD, for example, can I have another chart of the AUDUSD running as a time chart? It would be nice if u guys did video tutorials about this. Anyway, keep up the great work! Thanks. |
[2016-11-13 21:20:33] |
The chart bars can be set to any time frame per bar. Not sure why this is being asked because you should not have any trouble with this at all. And existing charts that with a bar timeframe greater than 1 Number of Trades will remain the same. Refer to: Changing Chart Bars Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-14 07:05:29] |
Oh I mean in one chart I'm watching Volume charts and then on another one I'm watching Time charts. Just to be certain, whether I choose "Number of trades per bar" or "Days-Mins-Secs per bar", I should be able to go back and forth, correct? If I change, for example, the AUDUSD, to Number of trades per bar, and I have other AUDUSD charts open in a "Days-mins-secs per bar" setting, will these latter charts be affected? Thanks |
[2016-11-14 07:13:19] |
Yes. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
