Date/Time: Fri, 03 May 2024 01:14:29 +0000
SpreadSheets DDE
View Count: 1865
[2013-07-31 10:20:23] |
TastyRisk - Posts: 119 |
Will it be possible to paste DDE links into the new spreadsheet functionality ? DDE is widely used in finance and an implementation would allow SC chart to interface with dozens of other apps. Ideally we could specify Data/Trade Service settings to receive DDE quotes into a UART buffer which would write into a SCID (presume at the chart update frequency**.) I presume you have seen something similar on multiple-other-charting-software where each trade value can be assigned from a DDE source ? edit: Right now SC has a 40ms minimal chart update frequency. Seeing as 1000/40=25 then is it not reasonable to expect 25 intervals of real resolution per second at the tick level? I saw on another thread that you have some new code regarding milliseconds, so I don't know if this is relevant, but if it is then I think a 40ms quantization "compromise" is workable. Date Time Of Last Edit: 2013-07-31 10:31:18
[2013-07-31 10:33:20] |
Sorry; I edited the OP a few times!
[2013-07-31 17:30:21] |
No. We would not support DDE. That is totally out of date and Windows specific. It is not even reliable the last time we looked at it more than a decade ago.
