Date/Time: Tue, 07 May 2024 07:20:55 +0000
Plug-ins not loading
View Count: 1290
[2013-07-31 08:46:14] |
Possibly the files for these custom studies are in the wrong location. This is explained here: Notice: Required Location of DLL files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-31 08:46:27
[2013-07-31 09:18:53] |
Your Sierra Chart account is properly linked to the support board. Are you having any specific problem? Do you see the custom studies you are looking for in Analysis >> Studies >> Add Custom Study? You will see a tree list. You will have to go to the very top of the list and collapse all of the branches to ensure you see all of the available groups of studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
