Date/Time: Sun, 19 May 2024 11:20:05 +0000
Syncing Average Price scale with undelying data
View Count: 1127
[2016-11-07 18:53:28] |
jackbravo - Posts: 65 |
Hello, I am using the price overlay study to map TICK to the ES chart, on an independent scale. Next, I am using the Average Price study, based on the TICK data, and mapping it to the TICK chart. However, the average price line doesn't seem to use the same scale as the TICK chart. I am attaching a screenshot. If you see the value on the right of the Average Price (yellow) line, it's not in line with the scale on the right (see bottom right red bracket). Date Time Of Last Edit: 2016-11-07 18:54:14
SC Moving Avg Scaling independence.PNG / V - Attached On 2016-11-07 18:50:57 UTC - Size: 98.35 KB - 184 views |
[2016-11-07 19:31:42] |
Make sure all of the studies in the Chart Region where those studies are displayed have a Scale Range set to Automatic: http://www.sierrachart.com/index.php?page=doc/Scaling.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 19:57:39] |
Thank you, that worked.
