Date/Time: Sun, 19 May 2024 13:25:04 +0000
Volume dollar
View Count: 776
[2016-11-07 00:39:30] |
Kinobe - Posts: 86 |
Hi I am looking for a way to display value for volume X price. is it possible with an indicator? thank you. |
[2016-11-07 19:12:36] |
Use the Volume by Price study: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php You can use this Input to display the volume numbers within each volume bar: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#DisplayVolumeInBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-08 01:49:39] |
No, what I would like is Volume multiply by Price for instance, if I am looking a stock like AAPL or CHK on 1 minute chart period let say volume is around 100k/minute and the price is trading at 5$. so the indicator will show 500k$/minute how can I get that with sierrachart like the attached picture? thank you Date Time Of Last Edit: 2016-11-08 04:02:07
DollarVolume.jpg / V - Attached On 2016-11-08 04:01:12 UTC - Size: 295.64 KB - 255 views |
[2016-11-08 04:17:57] |
Have a look at the Study Subgraph Multiply study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s260 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
