Date/Time: Sat, 04 May 2024 00:19:05 +0000
How to change default data/trade connection upon start-up
View Count: 1323
[2016-11-07 00:35:29] |
jakesans - Posts: 50 |
Hi SC, I am no longer with Amp Futures using TT data, but that data/trade connection is what my platform defaults to at startup. I am now using Rithmic feed and want that connection to be my default connection. How do I switch this? My apologies if I am missing, but I have spent an hour looking at the various settings to try to change, but can't figure it out. I thought it would be in the Data/Trade Connection settings under Global Settings, but didn't see this option there. Thanks, JS |
[2016-11-07 00:54:39] |
We have set your account to not automatically use the TT FIX connection. So this is resolved.
[2017-12-15 19:32:08] |
User905938 - Posts: 10 |
I have been trying to setup Sierra Charts to default to my Rithmic US data connection; however, when I close and reopen or it gets disconnected it tries to connect to CQG which I do not have. I have it setup to use Rithmic, and after I select it from the list it has my user/password, however when I close and reopen the program it defaults back to CQG? |
[2017-12-15 19:48:14] |
We are solving this for you now.
[2018-12-27 02:44:14] |
User120942 - Posts: 71 |
I am experiencing the same issue as the previous users when logging in to my AMP account on startup the platform tries to connect to my previous CQG Fix login. I changed from CQG FIX to Rithmic awhile back. I tried to correct this by opening the Data/Trade Service Settings panel then checked the boxes marked "Connect on Program Startup" and "Reconnect on Failure" for my Rithmic connection and removing the checks from my previous CQG Fix connection but Sierra Chart keeps attempting to connect to CQG Fix on startup resulting in the same error message reported by the previous users..
[2018-12-27 04:27:20] |
This is solved for your account.
[2019-05-23 09:21:04] |
User243331 - Posts: 7 |
Greetings, I have the same issue as the previous posters. I connect throught Rhitmic but when I start Sierra Charts, it automatically defaults and tries to connect to the CQG Web Api data feed. How can I change it so it defaults to the Rhitmic Data feed?
[2019-05-23 13:34:37] |
Post #7: This is now resolved for your account.
[2019-05-24 02:17:05] |
Awesome. Thank you
