Date/Time: Sun, 19 May 2024 13:39:22 +0000
how to set default time zone as india
View Count: 652
[2016-11-06 02:49:48] |
User279714 - Posts: 21 |
in the following option how can i set it as default zone as indian tome zone. Because everytime i load new chart the time zone shows as use global time zone. I have already set the time zone as india in data settings http://www.sierrachart.com/index.php?page=doc/TimeZone.html#DifferentTimeZoneForCharts |
[2016-11-07 02:46:55] |
You just need to set the global time zone in Global Settings >> Data/Trade Service Settings: http://www.sierrachart.com/index.php?page=doc/TimeZone.html#Introduction So therefore, if the chart is set to use the global TimeZone, then it will use that time zone. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 03:06:17] |
I have set the time zone to india new delhi but when i open a new chart by default it shows the time zone as global time zone in the chart>>chartsettings>>advance settings instead of newdelhi
[2016-11-07 04:09:53] |
What difference does it make? The time zone of the chart will be New Delhi in this case.
