Date/Time: Mon, 29 Apr 2024 12:43:24 +0000
I/B order entry for FFA accounts
View Count: 1157
[2013-07-30 19:34:12] |
User29707 - Posts: 43 |
I am using SC with Interactive Brokers in an FFA account. Can I use SC to place orders into multiple accounts at one time and with instantaneous transmission,(no further drop downs to fill in before the order is placed). I am having issues doing this. Any suggestions. |
[2013-07-31 03:43:30] |
Yes. But we are doing some work with financial advisor account support. This should be done in 1 or 2 more days. So we recommend waiting and then we can help you with this using the latest version which has improved support for this.
