Date/Time: Sun, 19 May 2024 10:52:25 +0000
How to show EOD bar as finished
View Count: 968
[2016-11-06 00:37:22] |
User279714 - Posts: 21 |
I started using Sierrachart to scan NSE Indian Stock with Tradeguider. I have started using the SC Data EOD data provided by Sierra chart and I have a problem here. The tradeguider scanner generates a indicator only for a bar which is finished and now if we look into the following chart the bar of 4th Oct is still shown as under formation and not completed so i am not getting any indicators. How can we show this as completed as its EOD data and the day is already closed you can see the following chart and the symbol is VEDL.NS http://www.sierrachart.com/image.php?Image=147839218124.png Finally is there any possibility to connect to yahoo or google finance to get Indian stock data. |
vedl.ns.jpg / V - Attached On 2016-11-06 00:26:16 UTC - Size: 215.86 KB - 273 views Attachment Deleted. |
[2016-11-06 02:07:38] |
Tradeguider needs to solve the problem described. They have the ability to do that. Finally is there any possibility to connect to yahoo or google finance to get Indian stock data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-06 02:08:01
