Date/Time: Tue, 28 May 2024 07:31:05 +0000
Ratio alert
View Count: 564
[2016-11-05 18:10:19] |
User792599 - Posts: 3 |
Hello, I´d like make an alert with these conditions: if a ratio between the two top numbers on the ask side in bearish bar is greather than X, then do something... (draw a star, for example). The problem is: is there any way, how Sierra Chart can calculate a ratio between the two top numbers on the ask side (or, reversely, a ratio between the two bottom numbers on the bid side)? Thank you |
[2016-11-05 22:31:26] |
This can be done by using an Alert Condition Formula on the chart: Study/Chart Alerts And Scanning These are the relevant functions you need to use: Study/Chart Alerts And Scanning: Special Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
