Date/Time: Sun, 19 May 2024 08:28:34 +0000
Volume By Price ?
View Count: 741
[2016-11-04 10:06:48] |
User93103 - Posts: 48 |
Hello: After I installed the latest prerelease 1481, this morning i noticed: On all charts, volume profile is plotted only up to last closed candlestick Bar. Before, it included the unfinished candlestick that is not closed yet and displayed using the right aligned to the right of the chart or window. Volume Graph Period Type: From Session Start Time to End. God Bless Thanks Ben |
[2016-11-04 10:40:03] |
You need to set this Input to Yes: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
