Date/Time: Sun, 19 May 2024 06:52:28 +0000
Automated Spread Sheet Trading - Limiting Trade Session Window
View Count: 640
[2016-11-03 22:22:37] |
jakesans - Posts: 50 |
Hi SC, In order to limit time window of automated trading from spreadsheet study, do I need to add a formula into the spreadsheet study to disable the system during that time or will just limiting the hours on my chart settings take care of it. I only want to have the system working a portion of the globex session. Thanks! JS |
[2016-11-04 01:11:07] |
We recommend waiting until Monday next week for this functionality to be built into the Spreadsheet System for Trading study. It is not enough to just set the Session Times in Chart Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-04 14:40:59] |
Okay great, will this done via fields in the actual study or a new spreadsheet funcactuaa also, will details be included on change log on Monday?
[2016-11-04 15:08:42] |
Sawtooth - Posts: 4000 |
You can use cell J28 with a formula like this: =AND(J8=0,OR(J41-INT(J41)<TIMEVALUE("09:30:00"),J41-INT(J41)>TIMEVALUE("16:00:00"))) |
[2016-11-04 17:00:52] |
This will be controlled through new cells on the Sheet used by the Spreadsheet System for Trading study in the Spreadsheet. We will prepare documentation for it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
