Date/Time: Sun, 19 May 2024 07:24:01 +0000
bug in volume profile
View Count: 523
[2016-11-03 16:35:26] |
User560062 - Posts: 100 |
Hi, after i installed the latest prerelease 1480 i noticed a bug on volume profiles: see attached image for some reason, the right aligned composite volume profile was fixed on right hand side before, now it is moving and its hiding the last profiles. |
2016-11-03_17-32-22.png / V - Attached On 2016-11-03 16:34:24 UTC - Size: 17.23 KB - 201 views |
[2016-11-03 16:55:22] |
You need to set this Input to control this: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-03 18:09:06] |
yes i had that selected and still have a problem. This only happened after the update. Are you sure it is not a bug?
[2016-11-03 18:14:25] |
i checked again and you are right. I had it selected on the wrong one... thank you
