Date/Time: Sun, 19 May 2024 15:52:30 +0000
New Pulling and Stacking Column For Chart/Trade DOM
View Count: 2115
[2016-11-03 09:49:35] |
In the latest prerelease there are new columns for the Chart/Trade DOM for pulling and stacking of market depth data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-03 09:51:06
[2016-11-04 17:23:30] |
Mistic - Posts: 76 |
Thank you for this. I'd like to use this in spreadsheets. Where is the chart DOM pulling/ stacking arrays? so i can reference them and possibly add them to depth of market study code.
[2016-11-04 22:40:48] |
We will have to add the capability to ACSIL to access the market depth pulling and stacking data.
[2016-11-05 07:00:53] |
Ok. Thank you.
[2016-11-05 08:44:20] |
We will try to get these ACSIL functions out in a couple of days.
[2016-11-05 11:12:06] |
These functions will be in the next release of Sierra Chart: int (SCDLLCALL* GetBidMarketDepthStackPullValueAtPrice) (float Price); int (SCDLLCALL* GetAskMarketDepthStackPullValueAtPrice) (float Price); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-11-07 01:15:05] |
Rex1 - Posts: 14 |
thanks, will this can be clear any time? Rex Date Time Of Last Edit: 2016-11-07 01:17:41
[2016-11-07 01:56:45] |
We do not understand the question in post #7.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-11-07 01:56:55
[2016-11-08 06:47:33] |
Are the ACSIL functions included in this latest v1483 release?
[2016-11-08 08:13:54] |
Yes they are and they are documented.
