Date/Time: Sun, 19 May 2024 12:15:52 +0000
Time based order execution
View Count: 958
[2016-11-03 04:55:13] |
User150371 - Posts: 70 |
This is a feature available with R Trader and I wonder if it's possible with SC. It allows you to enter an order which will be submitted to the exchange only at an exact pre-defined time. |
[2016-11-03 05:12:29] |
There is not simple support for this but it could be done by using the Spreadsheet System for Trading study: https://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
