Date/Time: Mon, 06 May 2024 22:24:57 +0000
display past trades
View Count: 1274
[2013-07-30 09:33:12] |
This does not make sense. You should not be losing the order fill markers unless this is from a replay or back testing and you restarted and the option to save that trade activity is not enabled. Check the settings and the number of days to save in Global Settings >> General Trade Settings. You also need to be familiar with the Simulation Fills Source: https://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#SimulationFillsSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-07-30 09:35:09
[2013-07-30 16:37:34] |
We know what the problem is. This problem has already been resolved. Update Sierra Chart by selecting Help >> Download Prerelease.
