Date/Time: Wed, 21 Oct 2026 08:22:51 +0000
drawing tools in all graphs
View Count: 1294
[2016-10-31 09:28:46]
User805092 - Posts: 17
is any possibility to draw some objects and display them in all graphs with the same instrument? For example I'll draw extending rectangle as S/R zone to 30 minutes graph and I want to display this zone also on 2 minutes graph or orderflow graf.
Is any possibility how to do it without drawing the same extending rectangles to all graphs?
And one more question, is it possible to lock the crosshair tool for all graphs for the same time? I use more graphs and I need to scroll them in time all at once.
Thank you.
[2016-10-31 09:31:05]
We think what you are referring to is this:
https://www.sierrachart.com/index.php?page=doc/helpdetails72.html
Regarding the Chart Values Tool, refer to:
Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
