Date/Time: Mon, 29 Apr 2024 19:23:45 +0000
please combine "hand tool" and "chart value cross hair"
View Count: 1654
[2013-07-30 01:02:19] |
taipeicity - Posts: 52 |
suggestion after clicking the "chart value cross hair" icon and press and hold the mouse left button to activate "hand tool" as well, so I can move the chart the same time Qcharts have this feature, you can do it too. |
[2013-07-30 01:23:27] |
vegasfoster - Posts: 444 |
This is how I have mine set, which is what I think you want, make sure the following are selected/checked: Step 1, Global Settings>>Tool Settings>>General Tab>>After Single Use Change to: Hand Step 2, Global Settings>>Tool Settings>>Chart Values Tab>>Always On When Using Other Tools Step 3, Tools>>Hand Set like this you see crosshairs all the time and can grab and move the chart around by left clicking on mouse. Date Time Of Last Edit: 2013-07-30 01:27:27
[2013-07-30 01:46:15] |
The prior post, #2, should answer your question.
[2013-07-30 19:19:16] |
great ! thanks I love sierrachart much much more than stupid qcharts
Date Time Of Last Edit: 2013-07-30 19:19:49
