Date/Time: Wed, 08 May 2024 13:19:13 +0000
Sierra Chart Data corruption and intermittent updating
View Count: 1267
[2013-07-29 19:47:52] |
User49356 - Posts: 9 |
I am running version 996, service package 5, and getting data feed from OEC. It seems that data every once in a while gets corrupted and the chart updating also seems to be intermittent. The problem is usually resolved by logging off and logging back on Sierra. Sure would appreciate a solution as the date on Sierra Charts becomes unreliable. Date Time Of Last Edit: 2013-07-29 22:15:46
[2013-07-29 22:15:34] |
Please more precisely describe the "Data corruption" you are seeing. If you visually see something, then post an image of the chart, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Also you appear to be going over the OEC Symbol Limit : https://www.sierrachart.com/index.php?l=doc/openecry.php#Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
