Date/Time: Sun, 19 May 2024 04:55:30 +0000
Stock Trading
View Count: 584
[2016-10-25 20:19:02] |
User848740 - Posts: 12 |
I just about give up on Interactive Brokers and TD Ameritrade has difficulty finding stocks I wish to :Short" I am trying to have you connect to my computer and see if you can correct the problems with Interactive Are there any other Brokers that link seamlessly to Sierra's DOM that I can contact? a Fred Fred |
[2016-10-25 20:49:48] |
So you are saying that an order you submit from Sierra Chart to sell a stock and go short is getting rejected by Interactive Brokers? There should not be any problem with this. If there is any issue it might have something to do with the Position quantity not being properly detected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-25 20:50:18
