Date/Time: Mon, 13 May 2024 21:47:31 +0000
Moving average pointing higher or lower
View Count: 1046
[2016-10-25 06:31:23] |
User17477 - Posts: 65 |
Hi, What Sierra Chart indicator do I use to show me if a moving average is pointing higher or lower? cheers |
[2016-10-25 10:38:24] |
Look at these two studies: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s56 (Bar Difference) https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s231 (Study Angle) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-25 13:05:59] |
Sawtooth - Posts: 3995 |
You can also color the line based on slope. On the Subgraphs tab of the moving average study, set the Auto-coloring to 'Based on Slope' |
[2016-10-25 16:18:34] |
Thanks, I will use the study angle and also useful to know about the Auto-coloring 'Based on Slope'.
