Date/Time: Tue, 14 May 2024 04:00:26 +0000
Typical Price of NYSE TICK
View Count: 577
[2016-10-25 04:30:56] |
User150371 - Posts: 70 |
Hello , Tradestation has an indicator called ADE Tick indicator, which is a plot of the typical price of TICK. If the indicator is above zero then add that bar to the previous one and just keep a running total throughout the day ( vice versa if it's negative). How can I achieve this in SC? Thank you. |
[2016-10-25 10:34:13] |
Have a look at this study: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s134 If that does not do what you want, then use the Spreadsheet Study: https://www.sierrachart.com/index.php?page=doc/StudiesSystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
