Date/Time: Wed, 15 May 2024 00:51:33 +0000
Compiling Error
View Count: 725
[2016-10-24 22:37:30] |
User488039 - Posts: 114 |
Hi, I'm trying to compile a .cpp file I obtained on the support board. I'm new at this, but I think I followed the directions properly. I hope I did. The following is what I'm getting, and the .dll file was not created and put in C:\SierraChart\Data directory. -- Starting build of Custom Studies Source files: ST3bars2.cpp. -- 18:31:22 None of the selected source files contains the SCDLLName line at the top of the file. Refer to ACSIL documentation. -- End of Build -- 18:31:22 |
[2016-10-24 22:48:19] |
Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Make sure that file has the SCDLLName line at the top. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-24 22:48:32
[2016-10-24 22:55:21] |
Thanks for getting back with me. This is the top of the .cpp file, is this correct? // The top of every source code file must include this line #include "sierrachart.h" // This line is required. Although use only one per DLL project. // Change the text within the quote marks to what you want to name // your group of custom studies. SCDLLInit("ST3bars2") |
[2016-10-24 23:04:27] |
Change: SCDLLInit("ST3bars2") To: SCDLLName("ST3bars2") Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-24 23:10:32] |
Thank you very much. It compiled.
[2016-10-24 23:16:08] |
You do not need to say thank you. It creates more work for us.
