Date/Time: Tue, 14 May 2024 19:20:21 +0000
Importing Data
View Count: 911
[2016-10-23 11:14:07] |
turnbull - Posts: 34 |
I am trying to import CSV file as I have always done before. Somehow,it is not successful this time and gives me an error report as per attached. Please help. Message Log: --------- Compressing file: C:\SierraChart\Data\Import.NIFTY-NS-FUT-201610.scid.temp. This may take a while. | 2016-10-23 13:54:20 Beginning import of data from file: C:\SierraChart\Data\NIFTY-NS-FUT-201610.csv | 2016-10-23 13:54:20 Import failed to move the temporary file to the final output file. Windows error code 5: Access is denied. | 2016-10-23 13:54:35 * Compressing file: C:\SierraChart\Data\Import.NIFTY-NS-FUT-201610.scid.temp. This may take a while. | 2016-10-23 13:57:33 Beginning import of data from file: C:\SierraChart\Data\NIFTY-NS-FUT-201610.csv | 2016-10-23 13:57:33 Import failed to move the temporary file to the final output file. Windows error code 5: Access is denied. | 2016-10-23 13:57:45 * Compressing file: C:\SierraChart\Data\Import.NIFTY-NS-FUT-201610.scid.temp. This may take a while. | 2016-10-23 15:33:54 Beginning import of data from file: C:\SierraChart\Data\NIFTY-NS-FUT-201610.csv | 2016-10-23 15:33:54 Import failed to move the temporary file to the final output file. Windows error code 5: Access is denied. | 2016-10-23 15:34:09 * |
[2016-10-23 21:46:10] |
Make sure all charts are closed for this symbol: Import.NIFTY-NS-FUT-201610 and try again Also refer to this help topic: Error Messages When Opening Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
