Date/Time: Wed, 15 May 2024 00:08:55 +0000
footprint alert
View Count: 967
[2016-10-21 12:09:28] |
User819109 - Posts: 7 |
Hello I tried to put a alert on the footprint, I would have a sound alert on each Closing footprint, can you help me? thanks for your reply
[2016-10-21 17:38:09] |
If you want an alert when there is a new bar in the chart this can be accomplished with the Countdown Timer study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s201 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-22 20:48:21] |
thanks you
[2016-10-22 21:08:59] |
There is no need to say thank you.
