Date/Time: Sat, 18 May 2024 04:54:30 +0000
sc.Input[].SetCustomInputStrings() delimiter
View Count: 778
[2016-10-21 03:49:02] |
User553714 - Posts: 184 |
Hi, At the moment I think the only delimiter for SC function sc.Input[].SetCustomInputStrings() is ";" as per the documented example below; CustomInput.SetCustomInputStrings("Option 1;Option 2;Option 3;Option 4") The problem is when you have a combination of long strings and/or a large number of strings you end up with a very long series of characters (500 in my case) in your code which you can't shorten. I tried using a carriage return after each ";" to make the code more readable but the DLL wouldn't compile. This is not urgent, but can you consider allowing the use of a carriage return in this function in a future upgrade. Regards |
[2016-10-21 04:15:02] |
No, this is not something that we would do. This is so easy for you to resolve on your side by using multiple strings and joining them together or putting them on separate lines.
