Date/Time: Sat, 18 May 2024 05:12:00 +0000
intraday daily chart CQG
View Count: 781
[2016-10-20 16:30:30] |
AKR - Posts: 523 |
recently switched from TTnet to CQG. I used to have a intrady daily chart (1-0-0) for 2-300 days. Seems this is now limited to some 40 days app. Is that possible? Is all intraday tick data limited to 40 (??) days? Thx! |
[2016-10-20 16:54:33] |
Follow through the instructions here for a Continuous Futures Contract chart: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts Make sure the chart is set to the correct symbol which matches the symbols in File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-21 15:24:27] |
AKR - Posts: 523 |
no that was set right. otherwise I had not 300 days before switch. I only changed simbol. anyway - today it works why ever .... |
[2016-10-21 16:59:49] |
OK as long as the Symbol of the chart is set correctly and there are rollover rules defined for the symbol. it will work properly.
