Date/Time: Sat, 18 May 2024 05:12:06 +0000
Data
View Count: 870
[2016-10-20 10:49:36] |
User713850 - Posts: 33 |
http://www.sierrachart.com/image.php?Image=1476960132903.png For some reason historical bid/ask data is not loading into my charts this AM. When i try and change the lookback period on the charts as well it automatically defaults back to todays current data. As you see in the picture, the ask/bid volume difference indicator is not really loading at all. Please let me know how i can resolve this issue. Thanks, Brandon |
[2016-10-20 10:52:30] |
Change the symbol of the chart to a single digit year and do not use two digit years. You can do this through Chart >> Chart Settings. Make sure you do that for ALL of the charts. Otherwise you are going to have problems. After that reconnect to the data feed or restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-20 11:05:16] |
I am not understanding when you say change the symbol of the chart to a single digit year? So do you mean instead of eg symbol-ESZ16 change to esZ2016?
[2016-10-20 11:07:11] |
well whatever i did just worked....i went into "find symbol" and then clicked duplicate active chart. It loaded everything up correctly. Still not sure the exact reason it worked.
[2016-10-20 11:13:31] |
ESZ6
