Date/Time: Thu, 16 May 2024 03:24:40 +0000
VbP histogram displacement
View Count: 1349
[2016-10-19 13:43:29] |
User514370 - Posts: 62 |
Hello, I would like to "displace" VbP histogram in the chart, see the attachment (yellow circle). The point is how to set VbP study to display histogram 1. far away from the right side of the chart and 2. how to flip histogram to the left? Thank you! |
[2016-10-20 04:34:57] |
Refer to the following Volume by Price study inputs: https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_AlignToFarRight https://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#Input_RightAlignVolumeBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-20 05:57:48] |
Thank you for the reply. I surely tried this before asking with no success. Please, see the screenshot with my setting and the result. The "far right" doesn´t work for me. Thank you. |
[2016-10-20 17:12:54] |
So you do not want the Volume Profile aligned to the far right? We need to get your Chartbook containing a single chart with this Volume by Price study. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/PostingInformation.php#ProvidingChartbookSingleChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-21 09:03:58] |
I want to have one VbP aligned far right (see the blue circle) and second VbP just on the right edge. Sending you my .cht file and screenshot how does look like for me. Thank you! |
Private File Private File |
[2016-10-21 20:21:06] |
We understand this now. We will have to make a change to the Volume by Price study for the Align to Far Right Input to be effective for all types of single volume profiles.
