Date/Time: Sat, 27 Apr 2024 19:43:29 +0000
User Email Questions - diffrences or spread
View Count: 1288
[2013-07-28 22:58:38] |
Sierra Chart - Max - Posts: 5597 |
How do I create spread between the three contracts,
Or how do I create a diffrences between two charts # number Thank you. Sierra Chart Support |
[2013-07-29 10:38:00] |
user87297 - Posts: 6 |
Thank you but how can i create a spread between 3 contracts like YM - ES - TF in the example of "High Accuracy Spread" there is only between 2 contracts. Thanks. |
[2013-07-29 22:14:37] |
Look at the following studies: Difference (Bar) Spread-3 Chart They are documented here: https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
